N249 Location
sargey
Escaped mental patient
Aug 16, 2006
324
Weston-super-crapland
Ive searched and found nothing, hence the new thread.
Can anyone tell me the location of the N249 valve please, beezersport is gonna have a look on his but i cant see sweet F A!
Its an LC to be clear,
Ive tried following the pipe that leads to the top of the DV but it gets lost and i cant see where it goes
kez
Jan 29, 2007
1,014
Dewsbury, West Yorkshire
well mine's an LCR but it was under the engine cover.
unplugged !!
here's a pic, before i plugged it back in, and beezersport cleared the fault code :)
sargey
Aug 16, 2006
324
an LC hasnt got it ontop of the block. Its just the VAC reservoir. Ive been told its under the other removable engine cover by he dipstick but theres a few things under there with pipes and what not
sargey
Aug 16, 2006
324
The location of the N112 and N249 is as follows:
Under the second removable engine cover there is a metal plate with two nuts holding one pipe on and on the front one nut holding another pipe.
There are two allen bolts holding it onto the engine. They are a ******* to remove
Then under this is the N112 (on the left) and the N249 (in the middle)
The part number is 078 906 283 A and is £52 from stealers
Its held on by a rubber mount and is a right ass to get off
Its called a "solenoid changeover valve" to SEAT
So there you go, all the info on where it is and how much for the LC!
