Deleted member 10425
I have done a search but cant find what i am looking for...
I have a what seems to be a missfire on full bost, I have revo stage 1 and the car runs fine, I am running 21psi and was fine for a few months after i brought it. I have changed all the coilpacks and the spark plugs, so i have been told it may be the N75 ??
I have a C valve on mine at the mo, I called Seat and my engine code is AQX which they told me is rare ? but i am ment to have the F valve on so they say ? what is the difference ?
It only misfires if for example i am going down the motorway in 5th and put my foot down, has any one got anyideas ?
I am getting a code come up saying it is to lean, but i have no boost leak, changed fuel filter, and it is not the MAF, any ideas will help me out big time ?
thanks Dan.
n75 causing a missfire... i dont see it
the c and f valves are essentially the same
you sure you got the right spec plugs fitted?
might be worth looking at the oxygen sensors
what plugs would you recommend for that sort of boost ect?
