Nearside rear taillight not working
reidy4040
43
Corby
My nearside rear taillight is not working but the brake light on the same bulb is and the indicator is also.
Where does the power come from for this?
ZRZ
284
Hertfordshire
Just had a look and there isn't a fuse for the rear lights, they're fed by the power supply unit.
If the bulb is intact, try checking the connection for power, if all is well with that aswell, check that none of the connections are bent
reidy4040
43
Corby
Bulb is good, got a new bulb and still didnt work but tried it in offside and works fine. Put meter on bulb contacts and no 12v until brakes are pressed then the other element lights up.
ZRZ
284
Hertfordshire
So with the lights on, there isn't power going to the connectors until the brake has been pressed?
reidy4040
43
Corby
That's right. There's no power to the bulb when the lights are on unless the brake is pressed.
