dalian
Hi,
I am dealing with a very annoying problem.
Although my knowledge in this area is very limited, I will do my best to describe it bellow
Car details: Seat Ibiza 6l 1.4 TDI (2006), BNM
Car behavior: There are moments when I am almost unable to get the car moving, black smoke, "shaking" engine, poor performance
Diagnose recorder the following 5 errors:
1) 17932 - Fuel Pump Relay (J17): Open or short to ground
P1524 - 35-10 - - - Intermittent
2) 17849 - EGR Valve (N18): Open circuit or short to ground
P1441 - 35-10 - - - Intermittent
3) 19557 - Motor for Intake Manifold Flap (V157): Open or short to ground
P3101 - 35-10 - - - Intermittent
4) 17957 - Boost Pressure Regulation Valve (N75): Open or short to ground
P1549 - 35-10 - - - Intermittent
5) 18027 - Glow Plug Relay (J52): Open or short to ground
P1619 - 35-10 - - - Intermittent
I was told that this error might be cause by a malfunctioning ECU, which needs to be replaced ...
If anyone has any suggestions, I'd very much appreciate them!
Thanks in advance,
Dalian
Check your earths mate all those may share a coman earth,check a wiring diagram if you can.
Hello i´m joao from Portugal and I have the same problem but I don´t see the solucion you have repair car?
Hi,
Thanks in advance,
Dalian
Hi,you have resovld the problem???because i have the same problem
Thank you
