Apr 5, 2011
787
Somerset
Hey all need help ASAP, about to do cam follower on my car for fuel pump and it looks different to all other walk throughs it has additional high pressure pipe at bottom see photos.
I don't know how to remove the bottom pipe and I cants move the fuel pump back enough to get to the follower
It's a banjo bolt with an Allen key fitting. Un do it and make sure you don't drop the washers.
I had the same problem, I just undid all the retaining clips for the pipe and was just able to pull the pump out enough to change the follower with the pipe still connected.
