Robsparky
57
Snapped one of the spark plugs in the head. Tried all i can think of getting the 'B**tard' out. The others were very corroded in and need plenty of plus gas. I basically bored out the inside so it's really just the meal spark casing left. :cry: :cry: :cry: :help: :confused: :censored:
When i get it out will i have a problem with debris falling through into the head?
oh no, so what is left of the metel part that the socket sits over, is it a 16v or
8v? you could have problems with bits of debris getting crushed between bottom of the head and top of the piston. also it can bend a valve as it gets blown out past the exhust valves,
could you take the engine apart - remove the cam cover? just a thought i dont know?
