Can anyone recommend a half decent cheap VCDS cable? Want to have a play with VCDS lite, without comitting to the full version. I have an
Ibiza mk4, my dad a
leon mk1, a mate a
leon mk2, and my gf is about to get a mk1 TT. Anything that will work with all of those?
Gendan sell good quality cables.
Such a cable will work on your mk4,
Leon Mk1 and TT mk1, but the
Leon mk2 requires a CAN interface that are much more expensive. The full version of VCDS-lite will only cost $99 and is worth every penny (or cent). Once you've had a little play you'll see. I wouldn't be without it now, especially with 3 VAG cars in the household.
I am interested in carrying this out as well, please elaborate on
how to do these?
Always make a note of your existing
coding before changing them, just in case you have a
problem you can revert back.
Comfort wiper - address 46 central convenience --> recode --> add 8192 to your existing soft
coding number.
As for the alarm chirp and the comfort indicator flash adjustment, they are added by going to address 46 central convenience --> adaption 10. I am away from home so can't pull up the exact procedure until next month when I'm home again. But if you scroll up through the adaption channels, the program will advise you what to change, it's very self-explanatory. You'll see if/when you try it
I believe the Comfort Indicators can't be done a pre-facelift models?
No it can, my 2002 1.2 did, as does my 2004 1.2.
