DACA
63
Garstang Lancs
Hello I’m looking for help/guidance. I have just replaced my cambelt & electric water pump. Gen VAG parts used. No faults b4. Now code is in the DTC - P001600 Crankshaft Position-Camshaft Position Correlation Bank 1 Sensor A. The display shows a flashing glow plug coil and the stop start is no longer working as the central display flasher up stop:start error. Any suggestions b4 I strip down again and resin the cam crank & fuel pump. The bolt on the cam was tightened to 100nm and the Torx adjuster seems to be close to max limit. Any help would be wonderful. Thanks
