new k03s smoke...
Jul 4, 2007
1,674
bristol
hi everyone i fitted my k03s today all went well my old turbo had cracked and leaked coolent down the downpipe/oil
few questions
do new turbos smoke to start with till run in it was painted inside??
also the k03s seems so so loud on spoil up sounds like a jet plane is that normal?
im getting a lot of white smoke but im hoping its down to left over coolent/oil in my downpipe.
one more thing is it safe to run stage 1 map on a k03s???
Jan 13, 2010
440
UK
white smoke = burning water, so could be water in downpipe although id have thought that would only have been for a few minutes after start up.
stage one map will be ok to drive around not under boost all the time, get it mapped asap.
Jul 4, 2007
1,674
bristol
yer im running a can have been for a month before the new turbo my old turbo had blown but thier was no oil in the down pipe. im really at a loose end.
its chucking out a lot of white/blue smoke only done 120miles on the turbo also checked it this morning it spins fine with no play.
only thing i can think is my dv has broken
or it needs a remap to stage 2.
anyone any more ideas im really worrying.
May 25, 2008
2,400
cambs
Are you sure the turbo is at fault? If the turbo iS fecked it would smoke all the time . Have you thought about valve stem seals that would cause the smoke
Jul 4, 2007
1,674
bristol
the turbo isent at fault this is what im worrying about im hoping it will just go away i got the gargage to look in the head when mani was off and he said it has dry valves also had a compression test that passed.
would a sketch maf or dv make it smoke??
Oct 2, 2006
484
Im guessing your turbo probaly sounds alot louder than the previous old KO3 turbo because its a unsilenced KO3S unit.
May 25, 2008
2,400
cambs
I would say if your dv is shot it's probably not helping things depends if it's open or closed really
