Nitroverf - Leon Mk1 tdi 150pd & V6
AdamRoutley
Use The Force!!
Feb 22, 2007
1,827
Walsall
www.myspace.com
LOVE this picture!
andrew0171
nice job mate very nice
question is there enough space between the metal roof and the interior for the audi lighting?
Equalizer
103
Poland
Most impressive mods, but what have impressed me the most, were your electrician and mechanic skills.
I've got two questions: are the w8 center lamp and golf MKV light switch are plug&play ? And second question: how did you manage to install and get the instrument cluster working properly ?
J41R0
18
Hi Nitroverf,
You have here a great project ;)
I have 2 questions for you.
How did you knew the correct place and measures of the holes you had to do on your bumpers for the washers?
From which car did you used the plastic under stearing wheel to add the MK5 light switch?
bruceR
2,568
664
Monifieth, Dundee
Nitroverf, can you let me know how you went about installing and connecting the later version steering wheel.
Cheers for any info and this is a great thread with some indepth mods ;)
Thai-wronghorse
Self proclaimed Cupra R addict & butcher!
Dec 3, 2015
2,218
1,106
Kent
I appreciate this is rather old thread but there are so many oe+ mods in here that I've been considering for my FR that i need to ask i hope of some insight.
mk4 full FIS clocks - these i have already and just wanted to double check it was just case of transferring the guts to a Audi A3 8L housing?
Auto headlight switch - Do you need to use a mk5 switch for any particular reason or could i use a mk4 one i have already?
How come your switch and dimmer switch are separate as all the mk1 Leon switches ive seen are one complete unit. Do i need to source a different lower dash panel?
Mirror switch knob - what was that taken from, i used a Passat one in my mk4 but it never sat quite perfect.
Auto dimming rear mirror - is that from a TT...what year?
Climate control - Did you use LCD reversing film and change the LEDs to red as exactly how i want mine although i was considering the use of an Audi A3 8L one as the connections look the same.
kirwis
Nice project. Could you share info how you connect cluster? I have audi a3 8L cluster and trying to install in my leon mk1 tdi. It would be awesome if you share cluster pinouts diagram of oem leon cluster.
Thai-wronghorse
Dec 3, 2015
2,218
1,106
Kent
You can't use the 8L cluster board as the electrics differ, you need mk4 dials put inside a 8L housing.
