There are several things that could cause brake squeal. Has it had new brake pads? Has it been driven hard, so that the pads have overheated? Has it been driven so gently that the pads have "glazed"?
I don't think the brake pads are new (the car has been bought used), they could be the original ones. Anyway, they are in good conditions.
Since the car has been in my possession, it has never been driven aggressively. I also have a young daughter, and in any case, I'm not the type of person who thinks he's on a racetrack every time he drives... I certainly don't have an overly kind guide, let's say somewhere in "between" 😁
The noise appears occasionally, not always, it occurs when the engine is cold, especially in the morning.
What I would do is try to get the brakes hot, e.g. brake from a high speed with high pedal pressure, then carry on driving normally to get fresh air to the brakes so thy cool down evenly. There is a small chance that that might help. If not then I would take out the pads and if they are glazed/polished, sand the surface, and refit with some copper grease or something similar where the pistons push on the back of the pads. If none of that helps, I would be looking at different brake pads.
