Non starter
darren.sink
13
Hi. I have 2010 altea xl, it won't show any ignition lights or turn over help please
Sent from my SM-A300FU using Tapatalk
darren.sink
13
Yeh . Car cut out last week but started after a couple mins. Garage had it on computer but couldn't find a fault. Just when u turn ignition u can hear relay ticking but no ignition light/ handbrake light etc
cg82lee@gmail.
cg82lee
Feb 17, 2015
68
Sounds like a bad connection to battery terminal or wires somewhere , if showing no faults ??? I am all out of ideas ?
Sent from my Nexus 5X using Tapatalk
darren.sink
13
If it was a faulty ignition would the computer pick that up
cg82lee@gmail.
cg82lee
Feb 17, 2015
68
Check ignition fuses too , sure there is one for that , does anything else work ? Windows interior lights etc ?
cg82lee@gmail.
cg82lee
Feb 17, 2015
68
The fault needs to occur at the time to be seen , very difficult to see intermittent ones
lleiro
63
Don't know if you speak spanish and/or if I can post a YT link put this guy takes the relay 109 out and he taps lightly on it...
youtube.com/watch?v=LxkEMFlVMdk
This other guy found a fault in the Xeon headlight....
Go figure...
youtube.com/watch?v=YGc_LCOrJrk
lleiro
63
if it is similar to my 07 altea it will probably be on a panel left of the light switch. You remove the botton one for the fuses and the obd connector and the upper one will reveal the relays.
Could be on the engine compartment too. Gotta check the manual if you have it and this is probably a good read along with the link included in the thread:
forums.tdiclub.com/showthread.php?p=300195
darren.sink
13
The father in law removed the top 373 relay to go get a new one but they didn't have one so he just put it back in and hey presto it worked. Then bit later won't turn over
lleiro
63
Then that relay is going like the spaniard guy in the first YT link,
Is the 373 a light relay?
darren.sink
13
I've no idea what relay it is I cannot find any drawing of relay layouts
lleiro
63
I am trying to find what 373 does and all I could get is something like "Daytime Running Lamp Relay"
This seems to be a much better resource although when it gets to 373 it does not shed too much light:
volkswagen-polo-highline.blogspot.co.uk/2016/05/vag-relay-indetification.html
At any rate at least you have a suspect but 109 controls the ECU.
