Not Boosting Properly?! Causes??
Beaker™
Slightly Unhinged........
Nov 21, 2005
1,900
C:\UK\Glos
Car usually peaks at 1.5bar and holds at 1bar.
But today it will not peak past 1bar, its felt very sluggish for the past few days i was suspecting MAF. So tried unplugging it, but still peaks at 1bar, also borrowed someone elses MAF and still no difference.
What else would cause this? Changed a few vaccum hoses yesterday but all was fine after that. Started playing up today.
Quick reply would be appreciated as i got the bonnet open as we speak :)
flashbsd
n75? have you knocked the wiring plug out or anything or "disturbed it"
CupraUK
Pushing on
Aug 15, 2005
1,350
Bedfordshire
I'm with Flashbsd, I knocked the connector to my N75 when fitting my Forge DV and boost was very low. Pushed it on nice and tight and Mr Whistley came back.
Don't know where it is on the Beeza.
Beaker™
Nov 21, 2005
1,900
C:\UK\Glos
Right been up Ollys house and swapped my N75 with his, still not boosting properly. Have no access to VAG COM so cant log it :( REALLY doing my head in now!
Did hit 1.5bar twice on the way home in 2nd gear but that was it. :(
Been over all vac pipes and all other hoses and plugs that i could see. Also re aligned throttle body and unplugged ECU. Still no joy.
Beaker™
Nov 21, 2005
1,900
C:\UK\Glos
Martyn said:
It'd tell you whether the ECU is actually requesting and delivering the correct boost.
If your N75 duty is max'd but you're not building boost then you've got a big boost leak.
Oh right, well like i say i just tried an N75 that i know is working and that didnt help. Also checked everywhere i can think of for any kind of leaks. I'm at a complete loss now. No idea what to do next. :shrug:
Beaker™
Nov 21, 2005
1,900
C:\UK\Glos
Martyn said:
Find someone with vag-com and do what I suggested mate.
Will do, put up a post but i don't think there is anyone near me with VAG COM, i'm guessing the dealership will charge a fortune to plug it in?
traumapat
Leon Cupra IHI
Jul 24, 2005
5,925
sunny sussex
i had similar probs and it was my dv sticking... just a thought
Beaker™
Nov 21, 2005
1,900
C:\UK\Glos
Update, just took it out and it now its all over the place.....
1st gear peaks 1bar (slowly drops to 0.75bar)
2nd gear peaks 1bar (slowly drops to 0.75bar)
3rd gear peaks 1.5bar when it feels like it (holds at 1bar)
4th gear peaks 1.5bar when it feels like it (holds at 1bar)
5th gear peaks 1.5bar when it feels like it (holds at 1bar)
Before i started having problems it would easily peak at 1.5bar in all gears and hold at 1bar. Not a good day today :(
