Number Plate LED Bulbs
Leon MK4
223
Milton Keynes
Hi Guys,
I'm starting to get a little frustrated - I've bought 2 sets of LED Festoon bulbs for the rear number plate on my MK2 Leon. Both have claimed to be SMD Canbus friendly bulbs to show up no error codes on the dash.
Both sets I have put in, they come on for about 5 seconds then go off and display an error on the dash saying bulb out!
Is it just my car or is there a particular brand/type of bulb I should be using for these? I thought that as long as they were SMD Canbus friendly, they would be fine - obviously not.
If anyone knows how I can either get these to work or has a link to bulbs that they have used or are currently using without any problems it'd be much appreciated.
Thanks a lot
Deleted member 65851
Hi Guys,
Thanks a lot
You want these!
http://www.hids4u.co.uk/501-can-bus-360-degree-3-led-bulbs.html
Think there the same as the sidelights !
I've got them and perfect!
Just make sure when you've fitted them you lock car and then unlock and that will reset the system and won't show up as
light failure!
Mine match the Xenons perfect!
Gaz
tom.b
209
Nottingham
if you type in "STRATHY" at the checkout in the discount code bit it mite give you some off :) worked for me.
Cupra R
2,215
UK.
OP asked for rear number plate bulbs though and they are indeed the Festoon type.
I got some off Ebay and they worked first time and have never faulted.
Seller was Mylitco. Great service.
If you can't find them Leon MK4 post back and I'll try and get the full details.
Who did you get the ones you have now from?
Post a picture of the ones you have tried upto now?
Leon MK4
223
Milton Keynes
Morning guys,
Thanks for the response, regarding the bulbs I have bought, here they are:
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=360349145071&ssPageName=STRK:MEWNX:IT
It does clearly say that these are canbus error free - As I say, they do come on initially and to be fair, look very nice, but then after 5 seconds they go out. Am I doing something wrong, do I need to reset the computer or something?
I've changed the sidelights to LED and had no problems with them at all, they come straight on and stay on.
Cupra R
2,215
UK.
I have had some LED Sidelight bulbs in before which "claimed to be error free" but I kept getting errors every now and then.
I changed them with some from Mylitco and they worked first time everytime, and touch wood, never faulted in what must of been 12mths. So, I saw their number plate bulbs and bought a pair, same again worked perfectly and not had any bulb failure warnings. (they do only go in one way, polarity has to be correct.)
These are like the ones I got, but I opted for just 2 SMD's as I had read of others having three and reporting they were a little too bright.
http://www.ebay.co.uk/itm/36mm-C5W-...arts_Vehicles_CarParts_SM&hash=item3f02a182f9
Tfsi_Mike
2,386
Doncaster / Germany (Army)
Had no issues with these so far;
eBay item 370490211912
Seller hids-direct
£14.99
3 weeks so far with no issues, nice and bright.
AndrewJB
Friend to SEAT UK & Cupra Racing
Aug 16, 2007
11,163
483
Maranello
My Rear bulbs have been out for a while, i realised the other day but my CAN-BUS system hasnt flashed up to warm me
And Cold Diagnostics is turned on, stupid car
Ive bought some EBAY CAN-BUS LED bulbs anyway
Sep 19, 2010
552
Glasgow
Is it the 36mm ones u need for the number plates? Does anyone know what the LED bulb i would need for the DRL's within my headlamp it sits just above the side light?
Cheers Craig.
mlavery689
I had the same problem with the LED ones I bought, i had 3 defferent sets and all the same probems, I gave up!
vincent5525
Mechanic
Jul 2, 2011
267
uk, sheffield
Looks like you read my mind. I also bought some "canbus friendly" festoon LEDS. They come on and stay on, but after about 5 secs the warning comes on. Its just kinda annoying having the warning on constantly.
Sep 19, 2010
552
Glasgow
Just tried the ones in your link yesterday and they are throwing up error light and msg saying check numberplate light :(
Cupra R
2,215
UK.
Did you fit them one at a time?
If not you may have one in the wrong way.
Fit std bulbs back in, make sure they are working. Then, fit one of these LED's and check if it is working, if not turn it around as they are polarity sensitive. Once working, fit the other.
Sep 19, 2010
552
Glasgow
Tried one at a time, checked polarity etc. still setting off the error light. :(
Cupra R
2,215
UK.
I feel like I've done you an injustice mate, what can I say. Worked first time everytime for me (goes off now to find some wood)
All I can suggeat Craig is contact seller, let them know you have tried both ways, and they'll probably send another set.
Wonder if the newer cars are more sensitive??? Wouldn't of thought so.
Suppose you could always switch off Cold Lamp Diagnostics, but if it were me I'd want it to be stock.
