wasvw
help/advice please.got in the mk2 leon this morning and turned the wipers on but the drivers side did not move.there was no suggestion of a problem before today.i managed to get to the plug on the o/s motor even though I could not get the windscreen scuttle panel off[hows that fixed on ?] im reluctant to by a new motor on the off chance its failed.the wiring plug has three wires. it has a constant feed and earth but where does the small white/green wire come from.any thoughts or a wiring diagram would be much appreciated as the car's about as much use as a chocolate teapot in this weather.
regards WASVW
update.
I fitted a secondhand o/s motor today but still does not working ?
has anyone got any ideas please.
regards Chris.
There are 2 motors, the passenger one - master and the driver - slave
the master had 4 wires going to it - live, earth, trigger, signal
the slave has 3 wires - live, earth, trigger
if the o/s wiper still doesn't work after replacement then the signal wire is broken from the master motor or the motor is not compatible.
i have full access to vcds and it's showing no signal from passenger side wiper motor
however the passenger side wiper working and drivers side isnt
check continuity between the 2 wiper motors on the trigger wire...
thanks MJ car will be opened up today to check the above!
Also a lot of people telling me the motors need to be aligned and configured using VCDS - is this true? if so how? Ive looked everywhere but couldn't find anything
They need to be physically aligned to make sure they don't hit each other, other than that you don't need to do anything.
Thanks for the help guys! Managed to get it fixed, it was a faulty wire between the master and slave motors
belated update
after getting to look at a wiring diagram I was able to fix problem.
the green and white wire from the n/s motor is the signal wire that goes to the o/s motor.
this wire rather than going directly across motors goes into the main loom and has a connection in the dash panel wiring harness.i did a simple continuity test on this wire from the plugs on both motors.there was no continuity so had to be connection in dash.for a simple and reliable repair I ran a new wire from n/s to o/s motors and soldered wire in at both plugs.job done.
Does anyone have the wiring diagram mentioned above?
Here you go :)
EDIT (19th May 2025): Reinstated missing image.
I got this issues with my Mk2 too. I've worked out that it's a wiring issue as I bypassed the trigger signal going from the master to the slave motors with a jumper connection and all worked fine.
However in the process I've damaged the connectors. Does anyone have the part number for them? They look similar to Kostal/hirschmann connectors I've seen on other vehicles.
Also does anyone know the location where the wiring harness goes in to the dash? I'm either going to try and trace where the fault is or make the jumper connection a permanent wire!
The VAG part number for the plugs I believe you need is 1J0973724. There are some on eBay HERE.
Sorry, can't help you with that. Maybe someone else can.
Hi all.
Just to pick up on this can I ask a question please? I had the same problem and it only turned out to be the fuse (no 1 under bonnet box BTW). But the odd thing for me that doesnt seem right is that when the fuse is removed there is still power to the red/yellow wire to the master wiper motor. Also there is still power with ignition off and key away from car.
Is this correct or is something wrong?
Thanks in advance
Nigel
Hi guys, same problem here, think I’ve narrowed it to faulty signal wire, can anyone re share the wiring diagram as unable to load it, thanks guys
The wiring diagram image was originally uploaded to Tinypic which shut down. I've now re-uploaded the same image to imgur and reinstated it back into post #13 of this thread so you should now be able to see it again.
Reactions: R3k1355
