Options if it's the:-
*Bottom end:- Crank regrind and some big end/little end shells
*Head:- Replacement head and at the same time fit new head gasket, cam belt, tensioners and water pump.
Or install a good know VR6, cheaper than the 20vt but more power than the 16v.
I've destroyed 3 engines so far, all in different cars (Fiat Coupe 20vt, Pug 205 GTi x 2) and it may seem it at the time, but there's always a solution. If you're with the AA then remember you have the option (usually) of a 72hr courtesy car, which I made use of 2 years ago to tow a car to a garage and also to pick up a replacement engine etc. Best of luck!
