I will be taking you up on this now mate after replying to the thread, verbal_kint has found a full housing for just over £10, though I'll be doing as suggested above about making sure the cap is loose =)
The cap is hollow, it goes over the filter. Anyway,for it to be giving way enough to let the solid cast cup wrench tool to slip round means it has to be hollow.
As far as your oil filter is concerned, the worst you can expect is that is blocked with crud. The good news is that there is a relief valve in the filter housing which will open if the filter becomes too choked, so you won't lose oil pressure. But if that opens you will lose filtration, which you would rather avoid....
If it comes to the worst you can replace the whole filter housing, probably with one from a scrapper. It bolts to the block with four bolts, just needing new gaskets and some o-rings for the turbo feed banjo connection.
Ah, thanks mate and yeah I was really surprised that the new cup wrench slipped, I have to say that the new cup wrench was definitely a nice buy, just gutted about it not working due to the position the current cap is in.
Didn't know about the relief valve either and I'm hoping that's not what is happening! How quickly would you expect new oil to turn from golden to dark/black after an oil change plus oil filter change?
As stated above, verbal_kint has found a nice replacement for mine (the housing that is) so will be going that route, do you know what type of bolts, gaskets and o-rings I'd need? That way I can get them? Is there any specific torque settings needed for the new bolts? Also, not sure about this but going this route I know I need to drop the oil again but would I be creating a
problem putting the oil back in or would I be better off supplying new oil again given my oil is not even a month old yet?
you could cut the cap off but
problem is debris going in the housing, with it only being soft metal or cast aluminium you coul crack the housing with it being so tight, at least the cap was only £10.
One thing for sure is I don't want to be messing with debris in my engine bay haha, although when I get this sorted completely I'd taking that cap off one way or another to find out what exactly the condition the previous filter was in and just to prove a point to that cap that it will come off (albeit smashed to bits if it has to haha
The video below shows the filter change on an ALH engine,similar to the ASV, and gives you an idea of what the cap looks like inside.
https://www.youtube.com/watch?v=qEJU4Zq65GY
Cheers Muttley, nice find, see how EASILY that cap came off!
My cap is a rebel thanks to the previous turd cow boy.
Ok, so my last item wasn't the right one so how about this:
http://www.ebay.co.uk/itm/98-09-sko...292?pt=LH_DefaultDomain_3&hash=item2a3c20e964
£10.80 delivered AND 10 NECTAR POINTS!!!
What more do you want, get it and half hour later your troubles could be over.
Haha thanks mate, if I sounded disrespectful I'm sorry I didn't mean to as you're going out of your way for me and I appreciate it completely!
I've just had a gander at this and I'll be making a purchase though as stated from Muttley I'll be asking if the cap is loose first haha!
I don't want another stubborn cap!
I've seen this nectar points all over the place, what the hell are they for?
Well, you would need new gaskets and o-rings. And, make sure to ask the seller if the cap is loose . . .
Will definitely be asking that question mate, is there any chance you or anyone could post me to the right gaskets, bolts and o-rings so I can have them on hand to do please as I've not got a clue on what to get for this?
Agreed of course, and do you really think there could be another cap in all the world that is at tight as israar's!!!
I think when the last person fitted it instead of a smear of oil on the seal they used superglue.
I wouldn't be surprised if this isn't the only one this tight mate, maybe it's the first to crop up here haha but then again, I'm not like some people who have the confidence to butcher theirs in their engine bay haha!
LMFAO!
If someone ever used super glue on one of these man, I'd probably cry with laughter
Thanks again all, I really do appreciate all the
help and suggestions, much
for you all!
--Lee
