ToledoNorthEat
Richy - Full member
Dec 17, 2009
160
South Shields
Chaps and Chap-esses,
Today I noticed my oil level had dropped quite far in the past week so I went on the hunt for the cause! I have found that the area/pipework under the EGR is covered in oil, before I start taking my engine bay to bits is there anything located in that area that may be leaking oil? I know the EGR can leak oil so I am considering taking that out and replacing with a delete pipe. (Also want to know if the PD130 and 150 delete pipes will fit a non-PD 110?)
Advice please!
Thats what I thought, Just had a look at the EGR, the (excuse the technical term) rod that opens and closes the valve is covered in oil too what are the hoses that connect into the EGR? Noticed one of them was rather frayed....
Its the rod that is covered in oil, however think I've found what is leaking. The seal between the EGR and the manifold had a big drip on the underside... think I need to step up the search for a delete pipe for a 110!
