Oil Level
john_ach
75
After hearing about the TFSI drinking oil I thought it would be a good idea to check the oil on my 1.6 but found i have a really odd dipstick;
Now Im not sure where the level should be, im guessing somewhere along the threaded part.
Does anyone else have a dipstick like this?
Approx how much oil would it take to go from the min to max level?
Thanks for any help
LeakyTurnip
Mull Fember
Feb 11, 2005
165
N.Ireland
My 1.6 has the same strange dipstick...As far as I'm aware the oil level should be somewhere in the middle of the 'ribbed' bit.
john_ach
75
Is that true for yours then? Do I just keep adding glugs of oil n test it until its in the right place on the dipstick?
LeakyTurnip
Mull Fember
Feb 11, 2005
165
N.Ireland
So far I have not needed to add any oil, the level doesn't seem to have changed much since I got the car.
carl4x4
195
top to bottom is usually anything from 1/2 to 1.5 litres on most cars, so be careful as too much oil can be just as harmful as too little, as if it is too excessive it causes piston lock & nasty things like that.
ranni2
Hi there ive had problems with my ibiza mk2 ive changed the ignition coil as that had gone but it still wont start and ive put too much oil in the car help!!!!!
carl4x4
195
If you've put too much oil in, then can't you just drain a small amount? It's a bit messy but as long as it isn't hot and you don't get it in your eyes you'll be OK.
