Oil pressure 0.7 bar (10 psi) on warm idle. This normal?
DOLBY
2,934
98
North of London
www.facebook.com
Hi
I have a LCR. Just had new oil and volt gauge fitted. New oil breather, oil, sump clean, new dipstick and gearbox flush etc.
I have noticed after a run or driving normal when engine up to temp my idle oil pressure is about 10 psi. Once I have stopped there's a definite note change in the exhaust. My natural idle I have always felt was low (just under 1k rpm) but just wondering if this needs seeing to?
Also getting 4.8 bar when at 80mph. Isn't that high?
bigT's lcr
Delete. Beat. Repeat...
Feb 27, 2016
1,216
732
Leeds
Hi
Not sure on oil pressures but my idle sits under 1k after its warmed up. When it idled higher it was misfiring
DOLBY
2,934
98
North of London
www.facebook.com
Oh ok
Yeh after a run with various levels of driving when I come to a stop it dips down to 0.7 bar.
If I start the car and let it warm for 29 mins then it settles to 1 bar on idle. It's weird so after a drive it affects it.
bigT's lcr
Feb 27, 2016
1,216
732
Leeds
Oh ok
Ye i think after a drive the oils more than likley going to be hotter plus engine itself being hotter so may bring the pressure down with oil being thinner. Just a theory
Gokiwi64
Geriatric Member
Apr 26, 2014
1,379
722
Hockley, Essex
I believe it should be around
Start engine (engine oil temperature at least 80 ° C).
Oil pressure at idling speed: at least 1.0 bar
Oil pressure at 3000 rpm: between 3.5 and 4.5 bar
