Hi folks,
I've tried searching this but can't seem to find a solid answer.
I have a 2003 1.4 Petrol Ibiza and occasionally when I corner tightly (usually off an island) my oil pressure lamp will flash three times and then disappear, accompanied by the audible warning.
The first time this happened was a few weeks ago when the heat/sun started arriving in the midlands! Kacked myself when it went off as there's nothing more disconcerting than loud alarms and red lights going off when you're trying to drive.
I subsequently pulled over and checked everything looked okay under the bonnet, oil levels fine and no leaks I can see anywhere.
Also checked the oil level at home while engine was cold and it sits just on the top of the max marker on the dipstick.
It's happened maybe 5/6 times since?
So I ask the wise folk of SeatCupra; is my engine going to blow up or is it just having a hissy fit?
Cheers!
Cheers!
