Jul 13, 2009
502
Hereford
After reading a lot of reviews I thought it best to go and tear the car apart and add some sound proofing,
First I started in the boot after pulling all the trims out this is what was there
As you can see not a lot!
and under the rear seats
And I also took off the tailgate trims too to find this
Now I can see why the road noise is so bad in Leon's!!
Got a load of this
Tredaire Boardwalk Laminate Underlay
http://www.underlay4u.co.uk/laminate-underlays/tredaire-boardwalk-laminate-underlay-105-55-798.php
Which even with next day del was only £55 for 15M2
only down side to this is its not self adhesive so spray glue is needed.
Started to cut and shape the underlay
Covered the boot floor, quarters and rear panel and put all the trims back
added too the tailgate and trim
And added under the rear seat too
This is what I have done so far, I plan to do the four doors and bonnet, this only took me around three hours to do this too, and the first drive up the road and the difference is great, its like switching your radio from front to rear speakers cant hear the road noise from the back :)
So I nice cheap way to sound proof your leon, hope this helps anyone thinking about doing the same, will add the door next weekend if it don't rain !!
Good stuff. Couple of questions, how heavy is that stuff and how much did you use for the back end of the car?
Nice one, will be giving this a go. Just one question, did you have any difficulty in refitting the trims that you remove because of the sound proofing ??
I am also thinking of doing this but was going to used some "closed cell foam" that is listed on amazon. It has adhesive on one side and is 10mm thick.
Questions for allbutt55
- Do you think 10mm will cause any issues when refitting the trim?
- How much is required to cover the boot and rear arch area?
It's dead easy, I've had mine out before!
The seat bases just need a bloody good tug from the front.
All the boot trim comes out pretty easy - it's obvious how it comes apart when you start looking!
The stuff i used is very cheap £55 posted i have not even used 1/4 the roll yet but i plan to do my van too:)
If you used the 10mm stuff the floors would be fine but it maybe an issue in the doors,
I got the stuff because its made to reduce sound and is made of rubber, very thin 4mm i think and water just runs off it!!
About 2m2 would be plenty to cover the boot floor it just made sense to buy the whole roll as not much more money!
Hope this helps :)
