The temp on the outside temp is reading at least 10 degrees below normal, it is about 3 at the mo when it is really around 15. The frost sign is on the display and therefore a/c won`t cut in so it`s hot inside.
I have serched and picked up a new temp sensor today from seat, plugged in and it reads the same temp???? Switched back and forth, both are the same??
Can you adjust the readings or does anyone else have any ideas? I phoned Seat they don`t know but will vag-com it for £23 to diagnose the fault IF it can be found.
Any ideas??
Any ideas??
