Soldays
I've ordered a new Cupra Born V2 79kWh, Aurora Blue, delivery March 2027. Can't wait!
I visit Spain 3 times a year, each for 28/30 days. My current car, Toyota Corolla saloon has a flat battery in that time. There is no access to mains electricity, parked outside private parking. I've been using a solar trickle panel successfully - except Winter!
Cupra UK technicians will not allow this OBD2 solar panel on the Born. May affect sensitive electronics!!
I also have a Noco boost starter as a backup.
I know older Borns used to have trouble with parasitic drain, but things have gone quiet for newer models with updates. I'm hoping things are now better??
Any evidence one way or another please?
The newer battery management system *should* trickle charge the 12v battery off the HV battery at a standstill providing the charge level of the HV battery is sufficient enough.
Thanks James. That's what I thought.
Re: CUPRA Born
However I wrote to Cupra UK asking some searching questions. I know that Cupra won't give a definitive answer, due to worry about litigation! What do you/ anyone think of the reply. It doesn't look good for people in my situation. I can't take a risk of parking in an airport car park.
"Thank you for your patience while we consulted our Technical Team regarding your concerns about the 12V battery and leaving your CUPRA Born unused for an extended period.
Please find below the information provided by our Technical Team:
Privacy Mode / Offline Mode
Privacy Mode/Offline Mode does not reduce the vehicle's electrical consumption while parked. Therefore, enabling this mode is not necessary to preserve battery charge during periods of inactivity.
Remote Connectivity and Automatic Software Updates
Disabling remote connectivity or automatic software updates does not reduce 12V battery drain.
Over-the-air software updates are only carried out with the driver's authorization. Before an update begins, the vehicle will advise how long it is expected to take. Updates typically take approximately 45 minutes.
Further information can be found here:
https://www.cupra.com/en/owners/ota-updates
12V Battery Monitoring
While the vehicle is locked and switched off, certain systems can continue to monitor its status, such as whether doors, windows, or lights have been left on.
However, some vehicle systems may only perform checks or generate alerts once the vehicle has been switched on again.
DC-DC Converter and 12V Battery Charging
The 12V battery is normally replenished while the vehicle is running or while the high-voltage battery is being actively charged.
The system is not designed to automatically recharge the 12V battery solely because its voltage has dropped while the vehicle is parked and unplugged.
Extended Periods of Inactivity (30–40 Days)
CUPRA's recommendations for longer periods of vehicle storage are outlined in the owner's manual, including maintaining the high-voltage battery at the advised state of charge.
Our Technical Team has confirmed that there is no additional manufacturer guidance beyond the information provided in the owner's manual.
Battery performance during extended periods of inactivity can vary depending on several factors, including the vehicle's condition, battery health, ambient temperature and usage history. Therefore, it is not possible to provide any further specific recommendations or guarantees regarding battery discharge during this period.
We hope the above information clarifies the situation and addresses your concerns"
Does no one have examples of the number of days they have left their cars unused - in a car park/at home and either have been able to start the car.....or not?
I have a born that's been with me since March and parked up for months at a time, the 12v battery has never gone flat.
Thanks James, much appreciated, this is the sort of encouragement I'm looking for!
I've obviously ordered a New Born (which I was so impressed with at the local Cupra garage) so have no choice really, but I'm fed up (7 years) with having to call out Toyota Recovery, or laterly using a 'noco instant starter' on my Toyota Corolla hybrid. It can't be good for its 12v battery.
The HV battery (providing it has enough charge) should be able to support the 12v battery for prolonged periods of rest. The one I have is a 2025 model
Leave "Low Voltage Battery Protection" turned on in the app.
Tap the large button containing the car (in my case CUPRA BORN) at the very top of the app first page > Click the "cog" next to you (Primary User) > Vehicle Permissions > Low Voltage Battery Protection.
Mine was defaulted to "Off" when I took delivery, so it's worth checking.
I've never had a problem so far, I do use my car infrequently, but I have only owned it for 11 weeks!
Thanks Eirona, it all sounds good to me. It all adds to the positive evidence, despite the cupra born technicsl dept. (see their response) not being very encouraging. Hopefully someone will say that they leave the car in an airport regularly without problem!
