Parking sensor problem
MattW35
156
Cambs
Has anyone had a problem with front parking sensors going off when ever you get below a certain speed. I'm assuming it's falsely detecting that I'm close to hitting something.
It started yesterday, I wiped the sensor that I suspected was causing the problem, and it seemed to stop doing it. It was ok this morning, then I washed the car and the problem came back again.
See pics, I'm assuming it's the sensor next to the number plate. There is something odd about the surface of the sensor, it's almost "bubbled" up a bit.
Any ideas if it's anything I can look at doing myself, or is there very little option other than a visit to the over so friendly dealers??
[/URL][/IMG]
[/URL][/IMG]
mrbugle
209
I had it in my last Seat and this one, I think it's interference from other car's parking sensors. Renault's in particular seem to trigger mine a lot.
MattW35
156
Cambs
I don't think it's that in this case, because that pic was taken sat on my drive with no other cars running around. Annoyingly, looks like I might have a real problem.
SwinDan
71
Swindon
Either it's taken a direct hit from a stone or someone's bumped your car in a car park or something even a slow speed impact can screw them up
MattW35
156
Cambs
Yeah i'm guessing it must be stone damage or similar. It's had that "finish" for an age, but it hasn't been a problem until a couple of days ago.
Is it a coloured cover on the front of the sensor, or are there different coloured sensors??
It's definitely intermittent. I've done a 300 mile round trip today. At the start of my journey this morning it was doing it all the time, mid way / when I got there, it was intermittent - but more often that not it was causing problem. On my way home, it was still intermittent, but more often that not OK. Hopefully it sorts it self out!
paddy6789
1,627
1,080
Preston, Lancs
Mine seem to behave a bit weird when moving slowly, and behind another car - it only seems to set off the sensors on the side where the car in front exhaust seems to be - wonder if it's the heat setting them off - or just my car saying I'm being an idiot and getting too close!
Seat Leon Cupra 290 DSG Black Edition
Racingline R600 intake
martin j.
1,996
891
Fife
I reckon it's just that, when on a driving course with an ex police instructor he reminded me of the T and T rule, stop far enough back from the vehicle in front so you can see T and T, tyres and tarmac, several reasons for this not least that a shunt up your rear may not push you into the car in front.
OP, It could just be a faulty sensor, we change quite a few at the dealer I work in, usually due to constant tones, but, that is of course after they've been faulty for a while.
paddy6789
1,627
1,080
Preston, Lancs
I follow that rule :) but always thought my sensors didn't think that was the case. Its only when moving slowly in traffic, and usually on warmer days. Does drive me mad when it happens but it doesn't happen enough to make me take it to the stealers.
Dougiebabe
10
Hi Matt
Did you get anywhere with your sensor? Mine is now going off all the time when below 10mph but instead of off/side mine is nearside next to number plate. I also have the same symptoms as you where the sensor feels like it has a bubble under the paint/on top of the sensor.
I know this isn't other cars interfering as yesterday I was waiting at a roundabout with no cars in front of me and it started as soon as I slowed down and didn't stop until I pulled off! It's annoying me so much now that I'm ready to turn off all the sensors!!
MattW35
156
Cambs
No, I haven't got mine sorted. It did settle down for a while, but it back being a right pain.
I'm currently planning on trying to work out how to get the old one out / and looking at replacing it.
Does anyone know how they are held / how to get them out. Also what the part numbers are / if you can get them from somewhere other than Seat. I'm assuming they're the same as VW use, and you can get plenty of them on ebay.
fer b16
Mexican Cupra MK3
May 30, 2017
12
Hi there, the part number of that sensor is: 5Q0919275C
MattW35
156
Cambs
Thank you both, that's perfect.
fer b16 - I presume you have to paint the front of the sensor to match the bumper?
Dougiebabe
10
Hi Matt, Did you ever get one of these ordered and fitted? Also guessing it needs to be painted to match the bumper and as the car has to go in for some work soon might get this done at the same time.
Cheers!
