PAS pump issues - What else does Auxiliary belt drive on Arosa 1.4 TDI MY2001?
comdw
My power steering pump is having issues - loud noises when turning steering at all (especially with low revs, no gas), but more worryingly the belt drive wheel for the pump is visibly jumping every now and then even at idle.
PAS fluid is all gone (could be the cause or a symptom of pump failure) so will be topping up first thing, but worried about risk of losing the aux belt altogether.
So I just wondered what else it was driving - alternator presumably, what about water pump? How much damage is it likely to cause or is it just going to be an inevitable break down (flat battery or over heating)?
Nath.
The Gentlemans Express
Jan 1, 2006
8,620
16
EASTLEIGH, HAMPSHIRE
I would guess that the alternator is driven by the same belt so if it wqas to come adrift the battery light would come on. Then you've got about half an hour of driving (less at night) before the battery dies and you have no spark etc.
MJ
Public transport abuser
Apr 22, 2008
5,508
13
Manchester
m.facebook.com
Put power steering fluid in then get the alternator clutch pulley checked as its probably seized which will cause the noise you are describing.
