This is strange...
Badger, is the asz from skoda fabia the same?
The n75 map is diferent...take a look to it if you can
Any advice? I'm modifying and I really don't know what values to use in the n75 map...
As soon as I can (need 15 posts to send links) I will post my mod map! If anyone want to see and give a help...
Just need the correct values, or I will damage my turbo...
Example, can I use n75 map from skoda? From audi? From vw? Or should I stay with this?
Run some logs of Group 11 and see if the car is overboosting. This will give you a better indication of the Turbo's behaviour.
4th gear from 1500rpm to redline will give you the best data to work from.
Badger can I ask you this...
What can happen if I use the n75 map from skoda? Will damage? Lose performamce?
Turbo may react differently, however the different will be minimal. As long as you run boost logs to ensure it's not overboosting then you should be fine.
badger, sorry for being such a pain...help me on this if you can, please
postimg.org/image/518qu43g3/
this map refer to what?
thanks
