beattie17
1,353
Perth
Im just away to start fitting my diff this week and dont really fancy using the bolts supplied by peloquin. Will standard VW bolt kit be ok? If so anyone know the part number?
Cheers Mark
I don't think the VW bolts will fit as the peloquin diff uses bolts and washers (threaded holes in diff) and the VW kit is bolts, washers and nuts.
I could be wrong though, i'll try and find out what was put in mine when it was rebuilt but prob won't be for a couple of weeks as the guy who built it's away at the moment
As Roly says. The 02J diff is threaded for bolts only. Have you got the ARP bolts supplied?
The ARP ones should hopefully be unbreakable. Ive still got to fit my new bolts. There really is nothing else to change to.
Peloquin sent out modified bolts to me in feb 08 after mine let go
Bolts and nuts this time without washers, i'd already had it rebuilt by the time they got here though so didn't use them and looking at them couldn't see how they were meant to fit without a bit of modification to the diff
Cheers i will check the morrow. If they dont where can i get ones from?
As the only uk agent for Peloquins we keep bolts on the shelf. Who did you get your diff through? if it was through us then in feb they will have been the new type bolts, but if you got from elseware then they could be the old type (might of been on the shelf for a wile)
If you could get a pic of the bolt put it up and i will say which ones they are :)
Luke
I bought diff off another forum, but not from a trader. Checked bolts and they aint ARP, how much are they arp bolts delivered?
ARP bolts are usually FOC from peloquins, but you will have to pay for delivery which if you go straight to peloquins is about £50! Jabba may have the ARP ones in stock, but they may charge for them.
Bolts from us are £45 inc vat and will be in stock mid next week.
Hope this helps
Luke
