Permanent live in fusebox
Acksaw
Confused
Apr 25, 2009
289
Newcastle, Staffs
www.acksaw.com
Hi all
Can anyone tell me which fuse is a permanent live on the interior fusebox? I am hardwiring a dashcam which has a permanent and switched wire, I've already found the cigarette lighter for the switched fuse but I want to use the permanent feed as well to record when the car is locked. The camera monitors battery level etc.
Any help predicate
Acksaw
Confused
Apr 25, 2009
289
Newcastle, Staffs
www.acksaw.com
I actually need both a switched and a live as the camera switches modes when the switched supply goes off to a lower resolution or a timelapse mode depending on what you set and then starts the battery monitoring
Can I just install a fuse into that lower position and keep the switched one active?
trebor
233
33
Worcester
I left the cigarette lighter fuse where it was and used a tap from that for my switched live.
Some of the unused fuse locations have live terminals in them - I found a permanent live which I used as permanent live to support the parking mode of the camera.
Biker
1,593
12
Northumberland
I found a picture that shows the permanent 12V connector. The red wire in the picture below is connected to the permanent 12V supply.
