Petrol Cap
marty_34
1,183
TEESSIDE
I think it's on the inner side on the left, I'm no technical wizard I'll see if I can get you a photo on my phone
marty_34
1,183
TEESSIDE
From what I gather they filed the edges down on inside edge and oil / lubricant applied
ERIC3451
103
Northern Ireland
The penny has dropped. Got it now :)
There appears to be two possible problems. One with the actuator itself and one with parts fouling in the petrol flap assembly recess.
Like crisRibiza mine was the actuator itself. The petrol flap eventually wouldn't lock with the central locking rather than have difficulty in opening it. Although for first time opening my flap needs to be pushed directly on the position over the actuator "piston"
Some day I might act on the experience of member glenh and open up the old actuator and see if a clean up and lubricate the inners.
ERIC3451
103
Northern Ireland
glenh you say that you were able to open up your petrol locking actuator.
After several weeks, and out of curiosity, I had a go at removing the lid from the old actuator. Broke off all the small wedge clips that appeared to locate the lid to the actuator body, but the lid remains firm. Am I missing something?
glenh
13
It's glued on. If you open it you'll need to glue it back together.
p.s. be careful - there are spring loaded bits inside that will try to escape when you open it :)
Aardvark
242
Leeds, Yorkshire
Hi,
After a bit of advice.
When I unlock the car, the petrol cap is not releasing everytime. When I press the unlock button on the fob again it will release.
Any advice/suggestions?
Also when I lock the car, the petrol cap lock makes a rattle noise around the release?
Does it need a replacing?
Ads
IIRC each key is driver specific and can be programmed to unlock drivers door only with a single press or all doors and boot with a single press. If it is configured for drivers door only you will require two presses to unlock the fuel cap :)
