May 19, 2011
639
I'm Havin my spoiler sprayed today and edgin ever so closer to fittin it. Now I've had a quick play and looks slightly short on one side when u put it on the back where the lip of it sits on.
Anyone got any pics from above and from each side so I can see how it lines up? And how u bonded it on and where u put the bond as well
Cheers jay
check my readers ride thread, there's pictures of it from most angles, if you want a different one let me know and i'll put one up tonight.
THe bonding stuff,
1. don't use the stuff that came with it, it's aweful as i found out. nip to halfords or similar and get some windscreen bond which is how David @ Sere motors has recommended to others it be done.
2. you put the bond on in lots of little dots all the way around the edge of the spoiler, where there's that 1cm wide, slightly recessed bit, in there. It shows you in the instructions, though they're not that clear at times and took a bit of double checking so i didn't put the glue somewhere it shouldnt be.
Give it a jiggle, and a firm push to get it lined up properly, do this several times, until you can put it on in the right position first time everytime... you only get one attempt once you've put the glue on unless you want the glue everywhere!
I'd advise getting a mate(s) to help you, I did it on my own as i'm impatient but it would've been easier with two or three people.
