Adam had his LC running at 255 bhp I think the cam will help you achieve better power delivery I think get it through the range quicker and it shouldn't pressure the turbo to moch as it won't be requesting extra boost ect and like you said they sound mint I think if you got the dolla then do it
All cams do is move the power band around and give a bit more of it.You can't get gains everywhere and they usually move the power band higher up the rev-range at the cost of some low down power ie you open the valves more at high rpm which gives more power but its too much at low rpm so lose some power.Best to match them to your turbo really if you plan on changing it.
I no you have slightly other opinions on this as your rolling road never seems to produce such desirable results (and this is in no way me saying your wrong) but you can only go from the results the rollers gave your car and more than one person on here had claimed to have 250 plus on a ko3s and one was after a jabba sport remap which jabbasport then confirmed when I was there as I asked the question. So he wasn't bigging his car with made up figures. But like I said you can only go what your read out says
