It is still going strong need todo a turbo on it my only problem is need the car to get to work so can’t do with it off the road for a few days grr but need to just get it done may be book a few days off work and go in and take the turbo off and get it sent off and have two days at home till it gets back lol
Next mod for me if I can find a decent priced airbag
Before
After
So noticed one of my sidelights was duller than the other, turns out that 3 of the 9 smd LEDs were knacked.
Bought new set and fitted in 10mins
New lamps on left
With HIDs
How do they look without the dipped beam switched on as I've lost count of the amount of rubbish 501 leds I've bought over the years.
Sent from my SM-G960F using Tapatalk
They actually look decent and give out a fair bit of light for sidelight bulb.
Where did you buy them?
£4.89 for 2 bulbs, I don't think it's worth shedding a tear over 6 pence ha
Went to a cracking place (Pipe Dynamics) not too far away to have a dummy cat welded to the downpipe
Car's looking great:coolthumb
Don't you need working cat for the MOT? Wouldn't it be better to weld in flanges, so you could install cat before MOT?
If you have a friendly MOT tester you should be okay. It only specifies a CAT should be present then the emissions need to be low. The two are mutually exclusive but in theory inherently linked.
