Please HELP.. abs, traction control, tire pressure & steering assist dash lights.
dannymk2
Hello everyone, i'm new to this forum so be nice :)
So here's the problem.
Abs and traction control light came on a while back, scanned with vcds and found rear left abs sensor to be faulty, at one point i disconnected the battery for something (i cant remember) anyway, straight after the battery disconnect the steering assist warning light illuminated (yellow) i figured it just needed learning of basic settings but i found out its connected to the abs system, makes sense i suppose.
Changed both rear abs sensors for brand new bosh ones, upon doing this i noticed the abs rings were damaged and falling apart so i changed both rear hubs as well.
I've tried to do the steering assist basic setting but it just wont take it.
One thing i have noticed though is that the steering angle position (via vcds) shows 0* no matter where the steering wheel is. now i've seen in other forums people having the same issue and replacing the steering angle sensor hasn't solved this.
What im asking is, where do i go from here? any help would be appreciated. i really want these lights gone from my dash!!
Thanks in advance :)
dannymk2
Oh and here's my scan..
Chassis Type: 1P (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
VIN: VSSZZZ1PZ7R033294 Mileage: 200660km/124684miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine Labels: 03G-906-018-BMN.clb
Part No SW: 03G 906 018 DT HW: 03G 906 018 DT
Component: R4 2.0l PPD1.2 G 0231
Revision: --H22--- Serial number: SEZ7Z0F3605238
Coding: 0050072
Shop #: WSC 00191 264 15243
VCID: 7AFD82AA35A833CED59-802F
No fault code found.
Readiness: N/A
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
Component: ESP FRONT MK60 0101
Revision: 00H11001
Coding: 0006786
Shop #: WSC 06441 785 00200
VCID: 73E3AF8E12C2428696F-8026
1 Fault Found:
01486 - System Function Test Activated
000 - -
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No: 1P0 907 044
Component: ClimatronicPQ35 010 0502
Shop #: WSC 00000 000 00000
VCID: E9DF4DE6C00E0856AC3-80BC
1 Fault Found:
00898 - Control Circuit A/C compressor
010 - Open or Short to Plus
Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 E HW: 3C0 937 049 E
Component: Bordnetz-SG H37 1002
Revision: 00H37000 Serial number: 00000004357077
Coding: E1880F2F00041000001D00000000000000007F075C
VCID: 2B5377EE8A725A461EF-807E
Subsystem 1 - Part No: 1P0 955 119 A Labels: 1KX-955-119.CLB
Component: Wischer SE350 012 0403
Coding: 00056272
Shop #: WSC 06441
Subsystem 2 - Part No: 1P0 955 559 Labels: 1P0-955-559.CLB
Component: REGENLICHTSENSORH04 0090
Coding: 00137517
Shop #: WSC 06441
Address 15: Airbags Labels: 3C0-909-605.lbl
Part No SW: 3C0 909 605 L HW: 3C0 909 605 L
Component: R5 AIRBAG VW8 028 2522
Revision: 10028000 Serial number: 003B0PHB917+
Coding: 0021045
VCID: 2F6B63FEBE6A2666327-807A
Subsystem 1 - Serial number: 6332MSME12226C5E
Subsystem 2 - Serial number: 6342MSME123E0258
Subsystem 3 - Serial number: 6351HTS6K5Q6RN53
Subsystem 4 - Serial number: 6361HTS6VARUD483
Subsystem 5 - Serial number: 00000000000000000
Subsystem 6 - Serial number: 00000000000000000
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 AQ HW: 1K0 953 549 AQ
Component: J0527 636 0070
Coding: 0002042
VCID: 810F7546D87EE016143-80D4
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 005 0060
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No: 1P0 920 925 A
Component: KOMBIINSTRUMENT VO3 0422
Coding: 0000401
Shop #: WSC 06402 067 57207
VCID: 2D5779F6B466547600B-8078
Address 19: CAN Gateway Labels: 1K0-907-530-V2.clb
Part No SW: 1K0 907 530 H HW: 1K0 907 951
Component: J533__Gateway H12 0150
Revision: H12 Serial number: 31001068188041
Coding: 3D3F034007000203
VCID: 2C5174F28F7C5D7E175-8079
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO VO3 0422
Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX3.lbl
Part No SW: 1T0 959 701 G HW: 1K0 959 793 M
Component: J386 TUER-SG FT 1124
Revision: 31008001 Serial number: 00000053488313
Coding: 0000688
Shop #: WSC 47696 476 82776
VCID: 3B7347AE7A12CAC68EF-806E
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K2 909 144 L
Component: EPS_ZFLS Kl.142 H07 1806
VCID: 356751965C361CB678B-8060
2 Faults Found:
02546 - Steering Limit Stop
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Mileage: 200650 km
Temperature: 31.0°C
Voltage: 14.00 V
Voltage: 13.80 V
00778 - Steering Angle Sensor (G85)
000 - -
Freeze Frame:
Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
Component: KSG PQ35 G2 020 0202
Revision: 00020000 Serial number: 00000000000000
Coding: 198000005283CC7F00060D0DE0085F86107C80
VCID: 83037F4EC262F20606F-80D6
Subsystem 5 - Part No: 1P0 951 171
Component: Innenraumueberw.010 4971
Coding: 00000000
Shop #: WSC 06441
Subsystem 6 - Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Subsystem 7 - Component: NGS n.mounted
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX3.lbl
Part No SW: 1T0 959 702 G HW: 1K0 959 792 M
Component: J387 TUER-SG BT 1124
Revision: 31008001 Serial number: 00000165488215
Coding: 0000688
VCID: 3C7144B27F1CCDFE875-8069
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
Part No SW: 1K0 959 703 N HW: 1K0 959 795 H
Component: J388 TUER-SG HL 1107
Revision: 11005001 Serial number: 00000000500825
Coding: 0000144
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
Part No SW: 1K0 959 704 N HW: 1K0 959 794 H
Component: J389 TUER-SG HR 1107
Revision: 11005001 Serial number: 00000000505264
Coding: 0000144
End ---------------------------------------------------------------------
