Have had the car since end July 06 and like it very much. Has only done 3800 (mainly local) miles.
1. When checking the oil level I see white sludge ('mayonnaise', I've heard it called) in the filler cap. I know the mainly local driving can contribute to this sort of problem - but I do give it a run on the motorways occasionally - and I wouldn't expect to see this problem on a nearly new car.
2. Whenever the ignition is switched on, with the engine running or not, there is a ticking noise from under the dash. It's like an erratic clock tick which varies in pitch. I've tried turning the radio off, and the climate control completely off but it makes no difference.
3. Associated with 1 above - I find the oil level on the dipstick very difficult to read. The oil is fairly black and the dipstick is black. I've not had this problem on any other car in more than 30 years. Does anyone know how to get a reliable visual indication of oil level on the stick?
4. Yesterday, for the first time, the car seemed to be running on less than 4 cylinders when started up from cold (approx. 10°C ambient). It would not run properley. I turned the engine off and re-started and all was OK again. Anyone had such a problem?
All help much appreciated,
