i put no, there wasnt a 'not yet' option!
really hope it gets a recall.......................... (he says biting his nails)
ibizacupra said:not good odds tho is it
Greg Kirby said:I have a 2001 Ibiza Cupra. Fortunately the fuse first blew in cold weather (the engine survived) - I could actually smell the buring plastic - melted a lot of the surounding plastic. However, there was enough contact left to refit a new fuse (needs must!). Forgot about it for a month or two, then bugger me if the AC stopped working - check the fuse - blown again. So onto my third fuse and not much fuse box left.
I'm thinking about carrying a fire extinguisher in the car.
If you guys want to refer this issue to Watch Dog, then I will be more than happily provide my support.
I'm generally miffed about a lot of the quality problems with this car Broken clutch pedal anyone? Burnt out indicator contacts sir? fragile electric window switches, broken rivets on the crown wheel of the differential, rattles everywhere, faulty mass air flow meter, faulty expansion bottle fluid level probe, ignition coils, brake vacuum hose - I've had them all and only just cracked the 50,000mile mark!!
It's time to get some come back.
I do still love the car when it isn't melting, cracking etc..
Jonzy said:Ive just checked mine on lunch as ive got sorta slighty cooler than ambient a/c. Tried to pull the end 30amp fuse and and suprise suprise its melted into the casing.
Bad pics, shite macro.
