Poly Bushes
wagcupra1
144
Colchester essex
Hi guys after some advice. I've just brought my koni suspension and while i'm there i was gon get some poly bushs and anti roll bars for my car? Has anyone thats fitted them had massive problems with the bushes as i've seen a few horror storrires and are they easily fitted? i have a hydroliv press etc in the workshop and how good are they cheers
h17och
the hunt is over. 460bhp
Sep 1, 2005
3,504
Dunstabubble
i run h&R roll bars
as for bushes i run poly front wish bone
and tt rear wishbone
seems to be a good set up
easy to fit if you have a press
wagcupra1
144
Colchester essex
tt rears? they a little bit stiffer then? think there the ones that poly ones fall out. Wt size roll bars u running mate? sorry ain't got bk to u yet haven't had 5 mins too look in the stores for a manifold been stuck rebuilding a vr6 corrado
h17och
Sep 1, 2005
3,504
Dunstabubble
front wishbone, rear bush yea!
im running 25mm frnt 28mm rear iirc
speak to alex at tts tell him hooch sent ya he can sort you with the ARB's and all the bushes at a good price :)
TurboCupra
190
The front wishbone rear bush is the most important bush, it the one that deforms the most under braking/acceleration and cornering, the stiffer that bush is the more constant your geometry is..
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
consider Vibratechnics front wishbone rear bush
as used by badgerwagen all this season.
allows movement in the right directions without binding like polys do
