turbomick onvi yellow cupra r Apr 12, 2011 401 1 halifax Mar 13, 2013 #1 Does any 1 no why they put a packet of grease in with the powerflex bush I've had no Reson to use it
dgjdrummer Part-timer Nov 5, 2011 1,301 4 Wrexham, N. Wales Mar 13, 2013 #2 For fitting in to tight spots I imagine?
RaviR50 Active Member Aug 15, 2012 2,425 5 Southampton Mar 13, 2013 #3 im pretty sure its due to vibration, you wouldnt want the vibration wearing the bushes so the grease makes them slip instead of rub
turbomick onvi yellow cupra r Apr 12, 2011 401 1 halifax Mar 13, 2013 #5 Cheers lads am doing the top mounts tonight so ill grease wer they meet the car
hyphon12 Daft Member Jun 7, 2011 1,101 5 Scottish Borders Mar 13, 2013 #6 The grease they supply is just standard copper grease, so if they start squeaking in the future you can just get normal copper grease to re-lube them.
BigJase88 Jase Apr 20, 2008 3,748 1,073 Mar 13, 2013 #7 It isnt standard copper grease its finer Standard copper grease on bushes can wear the bush Superpro bushes actually use clear grease (cant exactly remember the type)
RaviR50 Active Member Aug 15, 2012 2,425 5 Southampton Mar 13, 2013 #8 jasc1988 said: It isnt standard copper grease its finer Standard copper grease on bushes can wear the bush Superpro bushes actually use clear grease (cant exactly remember the type) Click to expand... silicone grease probably
hyphon12 Daft Member Jun 7, 2011 1,101 5 Scottish Borders Mar 13, 2013 #9 jasc1988 said: It isnt standard copper grease its finer Standard copper grease on bushes can wear the bush Superpro bushes actually use clear grease (cant exactly remember the type) Click to expand... Ah, ok fair enough lol. Although you can get fine "copper" grease fairly easily
BoostHard Complete Plonker Nov 25, 2012 1,391 1 At Work....... www.passionford.com Mar 13, 2013 #10 jasc1988 said: It isnt standard copper grease its finer Standard copper grease on bushes can wear the bush Superpro bushes actually use clear grease (cant exactly remember the type) Click to expand... My superpro bushes had a white grease
