pressure drop between turbo and throttle
robbellfth
I have had this problem for a while. now and again my Leon Cupra coughs and splutters. after taking it to my local garage the problem seems to be a pressure drop between turbo and throttle valve.
The codes are 17535 fuel trim bank 1 fuel to rich and 17705 pressure drop between turbo and throttle valve check DU.
Can anyone help with this problem?
RobM
Back from the dead...
Sep 27, 2006
4,982
Southampton
I had that combination of error codes when my MAF failed.
If you take it literally, it means your DV is on it's way out. It's always a good part to replace anyway, as it's a part that is prone to failure even on standard cars. But don't take it to mean that's definitely your problem.
