Pete 20vt
Has anyone experienced a problem with the brake pedal going solid at high speeds before going back to normal and allowing the brakes to work? I was out lastnight and went to brake slightly before a bend(cant say what speed
) , but the pedal pressed down slightly and was solid, there was nothing on the brakes. After about a second it went soft and worked as it should!?! Same thing happened again thismorning and is kinda worrying as it only takes that second for something to go very very wrong
. Anyone have any ideas what the problem could be?? Thanks Pete
