Problem coding RVC on Leon using VCDS
Youngers
27
Hi all im having trouble trying to code the rvc ive installed. Everytime I code my vehicle it is accepted but when I recheck the coding it has reverted back as if I haven't changed it. Ive have a 2016 leon 5dr 1.4 tsi with tech pack and no ops. Any advise or help would be appreciated :)
AndrewJB
Friend to SEAT UK & Cupra Racing
Aug 16, 2007
11,175
485
Maranello
Sounds like your version of VCDS isn't a fully licenced version and therefore can't make changes.
Youngers
27
Hi Andrew do you believe this is what is wrong? It is saying coding successful but i then turn everything off and lock the car for 10mins then recheck and the coding is back to default. Could you send me the link to the geniune vcds that I would need please if this is the case ill purchase the correct version :) thanks
AndrewJB
Aug 16, 2007
11,175
485
Maranello
you would need to purchase a real version from ross tech for like £250.
when did you get your VCDS from?
Youngers
27
Hi Andrew I got it off ebay. I am able to set adaptions with it like carbon look cluster but coding isnt working. As I say its saying coding accepted but its reverting back to original coding when I recheck it. Ive now ordered the genuine cable from ross tech, should have done this in the 1st place. I'll let you know when I get it :) thanks again.
Youngers
27
Hi Andrew managed to get the genuine cable and code my car but camera isnt displaying. Its bringing up park pilot then saying its unavailable. Have you any ideas? This is my 5F auto scan details before I changed anything.
Address 5F: Information Electr. (J794) Labels: Redir Fail!
Part No SW: 5QA 035 858 HW: 5QA 035 858
Component: MU-S-ND-ER H24 0245
Serial number: SEZAZ2R0674384
Coding: 04730001D70A000011111101008808002F0200C60120010046
Shop #: WSC 00049 770 00194
ASAM Dataset: EV_MUStd6C1TSAT 001015
ROD: EV_MUStd6C1TSAT_SE26.rod
VCID: 045285A6CE961907091-8050
Operating And Display Unit 1:
Subsystem 1 - Part No SW: 5F0 919 604 A HW: 5F0 919 604 A
Component: ABTm_Std2_Nav H44 1031
Serial number: SEZ8Z9RLM005LG
Data medium:
Subsystem 2 - Part No SW: 6P0 919 866 D HW: -----------
Component: ECE 2016 --- 0521
Serial number: --------------------
Youngers
27
Hi Kong no I just changed the coding in the 5F unit. I don't think I have park pilot as I don't have OPS installed in my vehicle? Would do you recommend coding ? Thanks again Chris
KoNG
539
126
London
to be honest with you i am pretty sure without PDC unit camera don't work as i haven't see any vehicle just with camera without PDC
Youngers
27
Hi Kong I have heard of a few vehicles having RVC retrofitted without rear pdc system. My head unit screen is switching to park pilot but its then showing a black screen and saying park pilot unavailable. I think its may be a coding issue and theres a different code to use for non pdc vehicles?
Youngers
27
Hi kong please read this link this guy has done it with no pdc
h t t p s://w w w.seat-leon.de/vboard/showthread.php?105028-R%FCckfahrkamera/page12
KoNG
539
126
London
its hard to say as the german forum doesn't says what version of infotainment is installed. your unit is the latest one so they may be completely different coding
Youngers
27
Hi all just a quick update I have now fitted the carsystems.pl rear ops kit but when trying to access the park assist module to code via vcds it is unable to communicate with it. I have also enables the module via CAN but still isnt communicating. Assuming this is a wiring issue somewhere? I have followes these instructions
w w w.clubseatleon.net/viewtopic.php?f=40&t=118998#p1912830
But I havent put a fuse into the fuse box as a have placed connector into the fuse box is the fuse needed to complete circuit, it doesnt advise in the instructions?
KoNG
539
126
London
file.php
the guide is correct if you put cable in fuse department as is on picture you need to put fuse in red square area marked on picture
unit cant work without power
Youngers
27
Hi kong judt put the fuse in and still no communication to thr module. Have you any other ideas?
Youngers
27
Hi kong measured both can lines and power feed and all are reading ok. Retested attempting to connect to module via vcds but it not receiving communication. Do you think the module is defective or is there something else which needs done prior to coding? I have already enable the module via can gateway but not sure if im missing something else? Thanks again Chris
KoNG
539
126
London
if the unit getting power and CAN high/low you should be able to see it after you activate in CAN gateway do you getting any error? Can you post your log?
What i would do it unplug all other cable, leave just power and CAN on parking unit, clear all error message from CAN gateway and scan it again. If this doesn't help the unit is faulty or wrong version for your car.
Youngers
27
Hi kong this is my log from the CAN gateway whenever I enable park/assist module. I am still unable to connect to it. As wiring is ok I am assuming that the module supplied in my retrofit kit is either incorrect for my vehicle or faulty? What do you think? Thanks again Chris
Address 19: CAN Gateway Labels: 5Q0-907-530-V1.clb
Control Module Part Number: 5Q0 907 530 AJ HW: 5Q0 907 530 F
Component and/or Version: GW MQB High 128 1243
Software Coding: 030100F42F085700EA000040000F00010001050000000000000000000000
Work Shop Code: WSC 00049 770 00194
ASAM Dataset: EV_GatewLear 013020 (SE37)
ROD: EV_GatewLear_013.rod
VCID: 79ACE452B95454EF6A7-802C
Fault Codes have been Erased
1 Fault Found:
131594 - Parallel Parking Assistance Control Module
U104E 00 [009] - No communication
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 23
Mileage: 3304 km
Date: 2017.05.08
Time: 19:15:10
Supply voltage: Terminal 30: 14.3 V
Terminal 15: On
