Had this
problem for a while, rear doors don't unlock from outside, sometimes even worse, they won't unlock from either side. From what I've found its a
problem in the front door, to temporarily fix the issue, I've found winding both the windows all the way down until they stop, then wind them down again and they should drop even more. Voila the door will unlock from the inside at the very least. Need someone who understands the wiring more than me to explain but basically the front door is the master and the rest are slaves, the
problem stems from the front door and not the rear, at least in some cases
