Problem with strut top mounts????
auq
Avoiding Potholes!
Feb 11, 2010
652
Leicestershire
Ive noticed a problem with one of my strut tops today, ive recently fitted coilovers and have noticed when turning the steering with the bonnet up only one side of the strut tops is turning freely, the other side doesnt move atall when steering is applied?
Should they rotate in situe when turning the wheel?
Or is something wrong
:confused:
Feb 26, 2009
5,275
Wolverhampton
I believe so, the bearing inside the top mount should turn more easily than the strut. If the strut is having to turn it suggests the bearing isn't doing it's job properly.
willpr
W11L PR
Oct 21, 2010
90
rochdale manchester
Neither of mine turn. Put new coilovers and top mount kit about 6 month ago. Sometimes while turning (not moving ) there is a groaning from the front. Also plate at top of susp strut inside bay has about a 10mm gap from top of strut. :think:
auq
Avoiding Potholes!
Feb 11, 2010
652
Leicestershire
i was reading Terry's post last night, im not sure if they are meant to turn, i think they are, once i know this i can strip and correct hopefully
auq
Avoiding Potholes!
Feb 11, 2010
652
Leicestershire
the whole lot turns on one side, cup washer, 22mm nut and shock insert, but on the other side nothing turns atall?
Feb 26, 2009
5,275
Wolverhampton
The gap is fine, it does just depend on the age of the rubber mounts but having a gap is no indication that the top mounts are worn.
auq, did you replace the top mounts when you did the coilovers?
