Problems activating traffic sign recognition
Snowman
306
24
I have a SEAT Leon ST Cupra 290 2016.
It has basicly everything thaty ou could spec the car with in 2016, lane assist, high beam assist, performance package, bucket seats, panorama roof etc.
However i did buy the OBDeleven dongle and app some time ago and noticed that i could enable traffic sign recognition through it.
This weekend i tried it but it does not allow me to active it.
Once i go into the apps section and into the app for traffic sign recognition it just says something like "not possible".
From my understand you need to have both cameras in the car to be able to use this, which i have.
But it seems as if OBDeleven is refusing me to even try and enable it.
Does anyone know why this is and what i need to do to be able to enable it?
Or do i need something else on my car to enable it?
p.eco
227
16
Ireland
I have activated this thru OBD11 but not via apps but via Long coding & adaptation. you can try it this way, the coding is somewhere on this forum or on the OBD11 forum. I also have sat-nav, not sure if this is needed or not but i know it has some connection to it. Do you have enough credit to activate this via apps? i think it cost around 100coins if i remember correctly....
Snowman
306
24
I do have satnav and 6,5 screen.
The problem is that I tried to enable it trough apps, but it says it is not available..
p.eco
227
16
Ireland
try this coding :
1 - Module 5F - Electronic Information 1. Code (20103)
2 - Adaptation
3 - Select - Car Function Adaptations Gen 2
4 - Search submenu - Menu road sign identification display (ON)
5 - Search submenu - Menu road sign identification display over threshold (ON)
6 - Select - Car Function List Bap Gen 2
7 - Search submenu - Traffic sign recognition 0x21 (ON)
8 - Search submenu - Traffic sign recognition 0x21 msg bus (data bus comfort)
1 - Module A5 - front sensors driver assistance system. Code (20103)
2 - Extended coding (Mode Bytes)
3 - Byte 1
4 - Enable Bit 0
5 - Adaptation
6 - Select - Show signals to speed limits
7 - Change value to On
8 - Select - Show additional signals valid
9 - Change value (100111)
10 - Select - Identify traffic signs fusion mode
11 - Selecting an option available:
- Fusion of traffic signs
- Traffic Signal Detection
- Electronic Horizon
12 - Select - Function Module Road Sign Recognition
13 - Change value to On
14 - Extended Coding (Text mode)
15 - Select - Coding HCA
16 - Change value Coded
1 - Module 17 - Code Box instruments- (25327)
3 - Byte 5
4 - Enable Bit 2
