Hi all,
Recently my engine's been running really really warm (probably warm enough to cook an egg on it, haven't tried - would it void warranty if I did?
) even though the engine temperature indicator on the dash says 90 (which is the normal temp for a diesel engine).
Today I did a 30min journey across London and about halfway through I could feel heat blowing onto my face and a strange plastic heat smell - kinda what you smell and feel if you put your face in front of a hairdryer on low heat (kids, don't do this at home!!).
After a quick look it seemed that the heat was coming through the air vents and the front windshield vent.
Bit strange since I didn't have my A/C or blowers on - which means that the air must be coming through from the engine somehow.
Anyways, when I got home I had a quick feel around the front of the dash and right at the front where the windscreen vents are it was extremely hot to the touch!!
I'm pretty sure this isn't normal, and a bit confused as to why the temp indicator says everything's running at normal temp.
And another thing, I've had it 5+ months driven about 5.5k in the car and never once have I had to fill up the oil or the coolant..... the coolant still shows full (actually when I got the car from the dealer it was over Full) and the oil is still between the two reader marks. Is this common with other FR owners?
Whereas my old Mk II Leon Sport TDI had to be topped up with oil every 1k and coolant every 2-3k......
Has anyone else experienced this? I'm gonna be booking it into the garage tomorrow for it to be looked at.
Oh, and while we're on the topic of engines...... does anyone else experience a funny 'ook ook' type noise if they've been driving in traffic with a lot of clutch usage?
Seems that this noise appears when I tap the accelerator gently to bring the revs from 0.9k (idle) to just above 1k....... and also when I'm putting the clutch down to change gears.....
Funny thing is, once you're on open road and doing a bit of speed it disappears...?!?
Not to mention the engine sounds really rough between 1.5k and 2k rpm.....
*sigh*
I just wanna drive my car without any issues.......... it's a joy to drive and these small niggles really ruins the experience!! >_<"
*sigh*
