Prosport Gauge oil
markojay
143
Aberdeenshire
Currently installing oil pressure and temp gauges but readings on gauges are at max!
Do you have to ground one of the wires from each sender?
Many thanks
truCido
Race Lupo in progress...
Dec 11, 2003
2,938
Bristol
www.vagowners.co.uk
ok well I was asking about the OP because there's a difference between the gauges and the non-premium senders need grounding I think.
The max readings issue is usually because of a grounding/earthing issue
