markojay
143
Aberdeenshire
Currently installing oil pressure and temp gauges but readings on gauges are at max!
Do you have to ground one of the wires from each sender?
Many thanks
ok well I was asking about the OP because there's a difference between the gauges and the non-premium senders need grounding I think.
The max readings issue is usually because of a grounding/earthing issue
