r/Road Help
higgsy regulato
Was just wonderin if any one could shed some light on rollin road!
How reliable are they?
I s my car gonna get reved to death sounds silly but you gotta ask*L*:happy:
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
your car will be revved to beyond it's maximum power rev under load, perhaps to the rev limiter.
higgsy regulato
your car will be revved to beyond it's maximum power rev under load, perhaps to the rev limiter.[/QU
So how bad is it for my car ive only had it 4 mths dont wanna go blowing it up:flamed:
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
does it blow up if you accelerate hard through the 1st 4 gears normally?
If your car is 'well' - ie fluids topped up & in good nick there's no reason to worry
higgsy regulato
I guess not as its still goin! My cars in good nick part from it just had to have a new slave cylinder fitted
Reg
Professional Detailer
Oct 10, 2005
962
Berkshire
Its at no more risk with a decent dyno operator than it is on the road - just think of the way some twats thrash their car from stone cold, yet they keep going. Prolonged dyno time can have issues with heat build up, on turbo cars especially. Just make sure your tyres are in good condition inflated to the correct pressure.
As for how reliable, thats very subjective. Different brands tend to give different results, so many different factors - ambient temp & humidity, tyre pressures, the way the car is running etc etc. There is lots of BS about it. The truest figure they can give you is the measured power at the wheels - they might also give you a flywheel figure (e.g. 225bhp for an LCR), but unless they take the engine out of the car and bench test it, this will be a estimated figure, calculated using figures to represent loss through the transmission. So comparing results with someone who got their car done on a different RR on a different day can lead to a few arguments.
What dyno time is very good for is perfecting your car there and then. Making sure the fueling is right throughout the rev range - not too rich, not too lean. Making sure there are no holes in the fueling gives a dip in the power/torque curves. It will highlight component failure too.
cuprablue
201
Very true and in fact what Dynos were actually developed for. Dynos are not that great for giving absolute results, (despite theoretically compensating for different atmospheric conditions), what they are good at (when used by a competant and experienced operator) is giving an indication of how a particular change has affected the vehicles engine output on the same day.
When making tuning changes to your engine you should at the very least use the same dyno (and preferably operator too) to assess the change.
cuprablue.
higgsy regulato
Thanks for the information,i never new it highlighted failure too.i look forward to my first roling road bring it on.
