r32 role bar?
L280R
153
Is it the mk 4 r32 21mm front role bar that everyone puts on the front of the lcr?
cheers
AndyHazza
Ex-Awesome GTi Staff
Mar 30, 2005
1,455
Bolton
www.awesome-gti.co.uk
The R32 one is a relatively straight forward swap on the LCR, you just need to change the bushes and brackets at the same time. There are quite a few different options available to you though, it just depends on what kind of budget you have and how much you want to reduce the role by. I'd recommend looking for a rear bar too, they really improve the performance on the LCRs.
Willie
LCR Track car
Aug 6, 2004
8,939
Sunny Scotland
cheers
There are two bars.
I have the 23mm one and would STRONGLY recommend this size.
Others fit stiffer ones 25 or 28mm, I haven't experienced these so cannot comment on them.
As Andy said, a 23mm R32 one with a 28mm rear Neuspeed one is a very nice set up
Willie
LCR Track car
Aug 6, 2004
8,939
Sunny Scotland
The MK4 R32 23mm front ARB with bolts, bushes and clamps was £100 from VW. A good £50 cheaper than the after market ones and built for the same sub frame so has the beads welded onto the bar to show you where the bushes go and to ensue it is correctly aligned
Willie
LCR Track car
Aug 6, 2004
8,939
Sunny Scotland
8n0411305d is the 21mm version
1j0411305af is the 23mm version marked yellow
of the r32 arbs
n10101603 is the bolt
1jo411336d is the clip
1jo411314r is the mountin bush for 19mm
1jo411314t is the mounting bush for 21mm
this might help was sent to me :)
Nice one Paul, to add to the above, there isn't a 23mm bush and the 21mm one does fit, 100%
Ronin225
4,652
22
Worcester
I was going to say isnt this about the time of year they do a neuspeed ARB group buy?
Its where i got mine anyway :D
L280R
153
I'd defo be up for a group buy on a rear neuspeed arb. Needs to be asap tho as it needs tobe on the car in 3 wks tops.
