Chrisdaman
1 gearbox dead, any more?
Mar 21, 2007
2,106
Kingston
www.flickr.com
i replaced the radiator, and now there are now leaks and it's not the head gasket, i'm wondering what else could cause the car to heat up
just wondered what temp do valvers usually run at? because before i fixed the rad it used to be at 100degrees and the needle on the oil temp would be in the middle. now i've fixed the radiator, it gets to 80 degrees and the needle is in the middle, but it keeps heating up to around 120
also where is the thermostat? i couldnt find it at all, i've bought a new one to replace the current one but my haynes manual doesnt cover my car. which one would cover my engine (ADL, similar to KR?)
sorry for all the questions
Chris
ive been told to watch out for air gaps when changing the coolant and this causes it to overheat. might wanna check that out open the cap and squeeze the hoses a few times to make sure it all goes around.
maybe theres an air lock in the cooling system, or maybe the water pump has broken? as alpine says, the clock on the dash is for coolant temperature, and the MFA reading is for oil...
if the pumps broken there wont be any coolant circulation to cool the engine down
Well a valver optimum running temperature is about 90 degrees (with the water gauge right in the middle) and the oil temperature usually climbs to 110 if you are pushing it very hard or sitting in some seriously hot traffic jam. 120 still does seem very high unless you are REALLY pushing it all the time (track day).
120 degree's is just not attainable on the road unless
a) your car is not well
b) you're driving in 1st gear flat out
120 degree's on the track, no problem at all
